line using cursor in xy graph
hi
how i can draw line using cursor in xy graph
(5,579 Views)
Hi bijal,
Not sure what you are planning to do. But you could start with:
  1. Creating a XY graph.
  2. Right click on the XY graph >> Visible Items>> Cursor Legend.
  3. Right click on the cursor legend >> Create Cursor >> Free. Up to this step, you should able to create the cursor.
  4. To obtain the data from the cursor, go to your block diagram >> right click on the XY graph terminal at the block diagram >> Create >>  Property Node >> Active Cursor. This should create the property node for your XY graph. To change a selected property to write, right click on the active cursor >> Change to Read and it should be like below:
    Just input 0 to access the first cursor
  5. Expend it to access an additional properties >> on the second property, click on it >> Cursor >> Cursor Position >> Cursor X.
  6. Expend the properties until you see as below:
    It Cursor.PosX and Cursor.PosY isn't changed to write, do change it to write by right clicking on Cursor.PosX >> Change to Write. Do the same for Cursor.PosY
  7. Up to point 6, you should be able to obtain data from the XY graph cursor.
  8. Use those values to plot into the XY graph. I believe you'll need to find a way to plot XY graph by building an array of clusters.
Hope it helps
Warmest regards,
Lennard.C
Learning new things everyday...
(5,569 Views)
Accepted by topic author bijal
Hi bijal,
you might change the appearance of the cursor to show as horizontal or vertical line, so you don't need to draw the line on your own…
(5,555 Views)
Hi
Thanks for your suggestion.
But I want to draw the tangent line in graph to find intersection point .
(5,520 Views)
Hi bijal,
use an additional plot in the graph to draw the tangent line!
Use two cursors (maybe set to small crosses) to define two points of the tangent line…
(5,509 Views)
