linear interpolation
hello,
I would like to reduce the effective sampling frequency by linear interpolation from 5 kHz. How must I do ?
Thank you
Message 1 of 11
(5,735 Views)
If I understood you correctly, you have data sampled at 5kHz, and you want to reduce the effective sampling frequnecy, say to 1 kHz (just to illustrate the point)
Assuming data are in an array,  there are  many options
1) pick points from the array at indices that are multiple of 5  (0, 5, 10, 15,....etc)
2) average every 5 points
3) use the median of every 5 points
4) use a weighted average of every 5 points ,
etc....
Message 2 of 11
(5,726 Views)
Exactly, I have data sampled at 4kHz and I want to reduce at 3kHz.
Do you know what VI of labview do I use to do this. For example, what VI for mediane, for average ????
Thank you
Message 3 of 11
(5,719 Views)
try the attached vi, it uses linear interpolation.   Simple and illustrates the point
Message 4 of 11
(5,711 Views)
To use this VI, I must transform my signal in a array ????
But I have a small problem, I don't know how integrate the VI at my project.
Thank you
Message 5 of 11
(5,708 Views)
How are you getting the data ?  When you collected the samples, they are read as an array, and you probably saved them in a file ?
What is the format of your data ?  at least you should be able to have LV read it as an array
Message 6 of 11
(5,701 Views)
hello,
For the VI that you gave me, I put the VI in library user. But when I open the VI in an other VI, I haven't input or output. So, I can't connect it.
Thank you
Message 7 of 11
(5,677 Views)
You need to connect the control inputs and output indicators to terminals
Right click on the vi icon.....slect the right pattern.
then, select the controls and indictors and connect them to terminals
If you are not aware of that, I suggest that you review some LV tutorials
Message 8 of 11
(5,671 Views)
Dr. Imad
The VI you provided for the linear interpolation works well and very useful. I had a question though - Is there a way to increase the size of the new array to show all the numbers containing in that array. For example if the old sample rate is 1 and new sample rate is 2, and have 3 elements in the old array. The new array will show 3 elements only. (see attachement).
Any help will be appreciated. Thanks.
Message 9 of 11
(4,918 Views)
Message 10 of 11
(4,894 Views)
