linear transducer velocity measurement
Having a few problems with this one!!
I have a 0-10v Linear transducer which is attached to a hydraulic cylinder which in turn is controlled by a proportional flow control valve. Normally in this application I would use a flowmeter to provide feedback to the proportional valve but unfortunately i dont have one. Im trying to convert the 0-10v linear transducer signal to give a voltage output depending on the velocity of the signal, is this possible? I've had a look through the examples to no aval'
Any pointers would be of great help. Many thanks folks.
(3,035 Views)
If I understand correctly, you want to measure the floe rate of a fluid going through a pipe, but cannot use a flow meter.
How do you intend to use a linear transducer?  Are you measuring the valve opening and deduce a flow rate from it?  How do you deal with pressure variations?  and anything that may be affecting flow upstream?
(3,028 Views)
Thanks for your interest Ray, The hydraulic cylinder is moving quite slowly about 50mm/min but the load on the cylinder is increasing, so if I provide the flow control valve with a constant signal voltage  the cylinder will start to slow down thoughout its travel. As I said, normally I would use a flowmeter to provide feedback, pressure is not a problem. I think what Im trying to do is some how count the rising voltage from the linear transducer and measure the pulse width to give an output that I can input into a PID block along with a setpoint for example 5mm/min and the proportional valve will open enough to maintain the cylinder a t that speed.
(3,019 Views)
