link a single scroll bar to two arrays
I am trying to link a single scroll bar to a pair of arrays (one is dbl, one boolean; both single dimension), so they line up correctly as I move the bar. Any ideas on how to get this to work? I tried a cluster, but no luck (Maybe I missed somethng?). Thanks!
(3,458 Views)
Hi Templar,
use property nodes:
read shown array index (property "Index values") from 1st array and set the same indices for the 2nd array...
Message Edited by GerdW on 07-26-2007 04:03 PM
(3,453 Views)
If you're using the scrollbar on one of the arrays, Gerd's solution is effective. If you're using an independent scrollbar just respond to the scrollbar's "Value Change" event and set the index values of both arrays as Gerd mentioned.
(3,446 Views)
