link labview data with excel sheets
I would like to save the output of a cluster(containing strings and numeric data) in a specific format(each data in respective columns)
in an excel sheet.
how do I do it in labview??
I tried mathscript, is there any other way? If there isnt can u suggest how can I use it to solve the above mentioned issue.
similarly, can I recieve data in real time from excel sheets??
pls suggest.
(3,024 Views)
Accepted by topic author connoisseur
I think you should use the ActiveX to fullfill your requirements.
You can refer to this example
<LabVIEW Folder>\examples\comm\ExcelExamples.llb\Excel Macro Example.vi
Use activeX to write and read data.
Best Regards
Hu Yu
(3,011 Views)
