link to a vi from panel
I am running a main vi (A) that does most of the things I need. However, it happens that I need to run a standalone configuration vi (B) when the main itself vi is not running. What I do is to open B, run it and close it. Get back to A and run it. Is there a way to link B on panel A through a button? It is important that A is not running when B is. This would just be for my convenience.
thanks in advance,
mirko
(2,536 Views)
You can use an invoke node like this
(2,521 Views)
Is your application controlling hardware that VI B configures?  I'm thinking that VI A should be a State Machine architecture that calls VI B when it starts.
Jim
(2,518 Views)
