linking cRIO 9073 wireless daq
We are trying to connect two wireless DAQs(Using a wls 9163 chassis each) and a cRIO 9073 over a LAN. However when we try to deploy our program, we get the following errors
Deploying DAQmx Timing (Sample Clock).viDAQmx Timing (Sample Clock).vi loaded with errors on the target and was closed.
LabVIEW:  Failed to load shared library nilvaiu.*:setTimingTerminalAP:C on RT target device.
LabVIEW:  Failed to load shared library nilvaiu.*:setTimingI32EnumAP:C on RT target device.
LabVIEW:  Failed to load shared library nilvaiu.*:setTimingF64U64AP:C on RT target device.
LabVIEW:  Failed to load shared library nilvaiu.*:setTimingF64AP:C on RT target device.
However when we connect the DAQs to the cRIO directly, there are no problems
Kindly help us
Message 1 of 1
(2,437 Views)
