linking control to terminals on connector pane
Lately, I saw something string in LabVIEW 2011.  When I tried to link a control to a terminal in the connector pane, sometimes LabVIEW will refuse.  When I do the link, nothing will happen.  I have to do it a few times or restart my vi in order for it to work.  Has anyone seen this?
Kudos and Accepted as Solution are welcome!
(2,817 Views)
That is strange indeed.  I have not used LV2011 enough to have seen that.
Is it okay now?  Or do you still have the problem?  It would be good if someone else, especially NI could try to connect the control to the connector pane and see if they (someone else) can reproduce what you observed.
If it still occurs, can you post the code?
(2,813 Views)
 It is being discussed here.
LabVIEW 2012
(2,811 Views)
it only happens once in a while.  Once it goes away, it doesn't happen again.  I only happened twice for me on two different vis.
(2,809 Views)
