linux shared library does not work in fedora core 4
I have transferred an application that ran perfectly on fedora 3 to fedora 4.  It uses a shared library that I wrote in C.
The vis no longer appear to recognise this file as a  shared library.  I have recompiied the library in fedora 4 but this makes no difference.
Any ideas?
(2,663 Views)
Hi jbroughton,
There are few things that I need to know in order to investigate why your file is no longer being recognised:
  • What version of LabVIEW are you using?
  • What is your kernal version of federa four?
  • Is your application a built executable?
  • What is your librarying doing currently when you try to call it? If any error popups what are the error codes and messages you are getting?
  • Can you call your C library outside of LabVIEW?
Emma R
NIUK & Ireland
(2,649 Views)
