list folder to stop displaying error dialog
Hi I have a list folder vi in my main program. It displays an error dialog when there is no folder. How can I stop this Vi to display the errror dialog? I disabled the auto error handler in the Main Vi bt this does not stop the list folder vi to display the error dilaog box. Thanks
(2,645 Views)
I'm assuming you mean you've unchecked the "Enable automatic error handling" option in the VI's Properties dialog (Execution page). What do you have the LabVIEW options set to? There are two options which can be enabled/disabled:
  • Enable automatic error handling in new VIs
  • Enable automatic error handling dialogs
If you have the error out wired to something (like another VI's error in, or to an error out indicator) then the dialog won't appear.
(2,632 Views)
