list folders in zip file
Hi
I want to list the files and folders inside a zip.
I read one post that suggested extracting everthing to a temp folder and then cleaning.  This is very slow and I only need two small files.
I have also been searching for a suitable dos command.
Anybody with any ideas on this?
Sean
(3,391 Views)
Hi Sean,
use one of the freely available ZIP command line tools to list the contents of a ZIP file. Using LabVIEW's SystemExec you can get that to parse the list...
(3,387 Views)
Accepted by topic author SeanJ
Thanks Gerd,
I wanted to avoid having to deploy more tools for installation.  There's PKZIP for DOS and ZIP for cygwin.
Anyway, there is a simpler solution.  Use labVIEW's unzip vi and select preview.
S
(3,381 Views)
It can be done with .net
(3,231 Views)
While we are resurrecting old threads, I use 7zip.  I have not tested the command line with the latest update, but it is fast and quite simple.
(3,226 Views)
