list tree change font
hi all ....
i am trying to change the font in the list tree .. but some how i am not able to use the property node correctly .. i try to increase its font or change its color or writing styile while the vi is running. I know i have to use the property node but its not working.
with regards
Regards
Message 1 of 8
(3,872 Views)
Hi nolsqn,
can you show what you have done so far? Do you get an error?
Mike
Message 2 of 8
(3,868 Views)
Hm, works quite well for me:
Please note that i suggest you to typify a combo box for the Font Name selection. The names of the fonts are e.g. Courier, Times New Roman, MS Sans Serif.
hope this helps,
Norbert
Norbert
Expert: Geometry
Message 3 of 8
(3,858 Views)
hi .. i have attached my vi ... i want to change its font in the run time ... also i m using invoke node to write on the list tree as it is running so on the front panel the diplay keeps blinking ... is there a way to remove it ...
also i need to change the font in rum time .. is it posible using the property node
 also
Norbert B you hav used multicolumn list box and i m using a list tree .. both have different properties .
Regards
Message 4 of 8
(3,844 Views)
The difference is very low in regard to your request. Instead of "Active Row", you would use "ActiveItemRowNumber". The rest of my screenshot is also valid for a tree control.
Norbert
EDIT: The blinking is created by the way you write the values: you repeatedly update the tree control with new values (even if they do not change) and you do it as fast as your system can execute it. This is bad. First of all include a delay in your while-loop. Secondly, change the content of the tree control only if your really want it to change. You are wasting lots of resources otherwise.....
Message Edited by Norbert B on 06-08-2010 04:54 AM
Norbert
Expert: Geometry
Message 5 of 8
(3,842 Views)
hi Norbert B.....
i have been trying to minimize the resourses.... but as u can see the names are contant which i donot want to write but i donot want to add the names every time ... if you mey be edit my VI .
Regards
Message 6 of 8
(3,831 Views)
hi i have modified my vi .. but still of no use .. i am getting an error that input parameter invalid .
kindly have a look
Regards
Message 7 of 8
(3,822 Views)
You should enter -1 or -2 for the ActiveItemRowNumber.
See image below courtesy of the Context Help:
Do you really need the outer While Loop?  I would remove it.  You could make your code a vi that gets called if you change any value(s).  That would eliminate the annoying blinking of the values.
Message Edited by Ray.R on 06-08-2010 07:54 AM
Message 8 of 8
(3,802 Views)
