โ11-27-2012 03:21 AM - edited โ11-27-2012 03:22 AM
Why would you populate a listbox with 16000 rows of data? Do you have some mechanism for helping the user search it because no one in their right mind would want to scroll through it. And as I said before, trying to put that much data in a listbox will be inherently slow. You would be better off filling the listbox with only that range of data the user would be interested in.
โ11-27-2012 03:23 AM - edited โ11-27-2012 03:24 AM
it's a data log, i need put all data together...
i'm just a student that is making a stage for university ๐ my boss said to me: "use listbox!"...i have to reply "yes sir!" ๐
Then he told me "make it faster"...and what could i reply? "Yes sir!" ๐
โ11-27-2012 03:30 AM
Ideally, for that much data, you would store it somewhere more appropriate and let the user search it and display the results. For example, a MS Access database. Or at least store it all to disk but only display the last N entries. Or display it all as you are doing then ask your boss to sit down and scroll through it and see what he thinks...![]()
For some reason, Dilbert just came to mind...
โ11-27-2012 03:35 AM
well my boss said me (and showed me) that he did it in past and it works in a great way...using listbox....
but he've forgotten in what way he did it :'(
โ11-27-2012 04:05 AM
I guess I would have to know your specific use case in this instance, otherwise, in my opinion, it's not a good programming practice.
โ11-27-2012 04:21 AM
โ11-27-2012 06:40 AM
DONE ๐
I solved the mistery...using a classic listbox is faster ๐ total perfect...thanks to all ๐
