listbox symbol size
Hello,  Anybody knows how to change the size of the symbols (or custom symbols) used by a listbox? By default Labview set my symbols to 16x16 pixels size and it is to small for me. Please help! Thanks
Message 1 of 8
(4,391 Views)
i think its 16*16 and can not be changed
Regards
Guru (CLA)
Message 2 of 8
(4,345 Views)
If you want you can replace the same.
search forum for that
Shrek
Message 3 of 8
(4,342 Views)
You can find an example called "Setting Custom Item Symbols.vi" in the LabVIEW Example Finder (Help >> Find Examples). Simply search for "listbox", it should be one of the examples listed there.
All symbols are resized to 16x16 (or something around this) if you insert larger images.
hope this helps,
Norbert
Norbert
Expert: Geometry
Message 4 of 8
(4,326 Views)
Hello, I have succeeded to make my own symbols, no problem. The only stuff I worried about is how to increase the size of these symbols. And I think that is really impossible to do.
Regards
Message 5 of 8
(4,311 Views)
I too need this option of changing the symbol size. Any suggestion?
Priyadarsini S
Message 6 of 8
(3,848 Views)
As the previous posts indicates, it is not possible to change the sybol size. Try the Setting Custom Item Symbols.vi from the example finder. I was not able to change the size.
Even
_________________________________
Certified LabVIEW Associate Developer
Automated Test Developer
Topro AS
Norway
Message 7 of 8
(3,846 Views)
Thank you, Even.
Message 8 of 8
(3,844 Views)
