listbox
hi,
in one vi named as login, i have 3 controls. username, pwd and one button password recovery. whenever the user forgets his password, he can click the password recovery button to retrieve the password. in the password recovery vi, i have given the required username and a submit button. whenever the user clicks submit button, the password has to get retrieved from the database and  should go into the login vi where the password control is there?
how can i do this in labview?
InAdvance Thanks
Regards
Soundarya
Message 21 of 34
(2,258 Views)
Start a new thread. Dont populate the thread with N number of question. If your problem solved mark the appropariate solution and close the thread.keep it as practice.
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
Message 22 of 34
(2,255 Views)
I ve used Cou Rouge's que mark w/o his permission...
- Partha ( CLD until Oct 2027 🙂 )
Message 23 of 34
(2,254 Views)
Okay Soundarya, here is some help...
Pass a Ref to the Password control of the Login VI into the Password Recovery VI & use the Value property tp update it with the value that you got retrieved from the so-called Database.
Actually, what is your DB? Just curious...
Message 24 of 34
(2,235 Views)
You could always use the way I use for this which is to attach the value to a global variable.  May not be the best way but it works and it can also be accessed by anyother VI you want as well.
Matt.
Message 25 of 34
(2,233 Views)
Hi Soundarya,
i don't like this way of storing passwords and i think your users also don't like it. You should store the password as a hash string. If the user forget the password, then you should provide a function to select a new one.
Mike
Message 26 of 34
(2,212 Views)
hi,
I am using MS-Access as my database. Since I am a novice in LAbview, can u please explain how do we pass a reference for any control.
InAdvance Thanks
Regards
Soundarya Pampineni
Message 27 of 34
(2,166 Views)
A funny thread indeed...:smileyvery-happy::smileytongue:
Message 28 of 34
(2,161 Views)
Hi Soundarya,
can you please explain what you need? You can create a reference with a right click on your control. You can then use a property node to write the new value to it or to change other settings.
Maybe you should think about a LabVIEW course.
Mike
Message 29 of 34
(2,149 Views)
hi, i know how do we pass a reference to a control. but i want to know whether that reference to that controls can be passed to another vi.
InAdvance Thanks
Regards
Soundarya Pampineni
Message 30 of 34
(2,137 Views)
