listen on two ports on the cfp
I tried posting this in the cFP forum, but I didn't get an answer, so I figured I try here.  I have tried to do this twice, and neither time did it work.  On a cFP 21xx is it possible to listen on two ports, using TCP over ethernet, at the same time?  Or is it possible to talk on one port and listen on another?  I know this is not standard, and it seems not to work, but I can't figure out a reason why not.  Is it possible, or is there something in the cFP that prevents this type of communication system from working?
Jo-Jo
(2,313 Views)
Hi Jo-Jo,
I posted an answer to this question in your original post listen on two ports on one cFP.
Please refrain from posting the same question to several forums. If you are not getting an answer in one forum please repost to notify any new browsers of the question. This keeps several people from the same answer several times in different places.
Michael K | Applications Engineer | National Instruments.
| Michael K | Project Manager | LabVIEW R&D | National Instruments |
(2,302 Views)
