Unfortunately, I don't have LabVIEW 8.5 so I can't look at the VI. I'm sure others can look at it, or you can post a screenshot.
As an aside, I'm a tad confused. I'm assuming this is a continuation of
this earlier thread, though you may be working on a different problem. You also said your network utility listed open ports. I'm assuming you're referring to TCP/IP ports. If that's the case, why are you trying to use the data socket VIs as opposed to the TCP/IP VIs? Do you have 2 LabVIEW applications trying to talk to each other? 'Cause that's the intended use for the DataSocket VIs.
