little green arrows on Sub VI's
The sub VI works great when i'm running it on its own but when it is run as a sub VI a little green arrow shows up and the program stops running but i get no error codes
(4,790 Views)
Do you have execution highlighting or breakpoints turned on?
"Bummerhunter" wrote in message
news:5065000000080000003AAF0000-1068850981000@exchange.ni.com...
(4,790 Views)
When you have Execution Highlighting (the lightbulb) turned on, the green arrow is shown on a sub-vi while it is executing just to show what's going on. Your program is probably not running because it is stuck in the sub-vi for some reason and can't exit back to the main applicaiton.
Open the sub-vi and look at the diagram while running with highlighting turned on there. You should be able to track the problem down.
Ed Dickens - Certified LabVIEW Architect
Lockheed Martin Space
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
(4,790 Views)
Ok i found the answer thanks for all your help it turns out to be the while loop in it
(4,790 Views)
