live imaq video crop
I am working with a thermal camera and I am constantly displaying a live feed.
Does anyone know how to crop the video and display it with a width x height set up by the user? Basically, the camera displays the logo and some other features that I would like to get rid of by cropping the edges out.
Attila
(2,862 Views)
You could either change the sensor width, height, and offset, or you could use the pixel manipulation VIs to only show a subset of the image. You could use image to array with optional rectangle input, and then array back to image.
(2,839 Views)
thank you for your answer. In the end I managed to find a straight forward method that worked for me. It helped me especially, as I am quite new to LabVIEW. I just simply used the IMAQ Extract Tetragon VI and wired my own coordinates for the desired window and it worked.
(2,793 Views)
Excellent, thanks for updating with solution!
(2,786 Views)
