lkstime.dll, labview 7.0
Hi, when I load labview 7.0, I have started getting the message:
"The application has failed to start because LKSTIME.dll was not found.
Re-installing the application may fix this problem."
Has anyone seen this problem before? What is has happened?
Before I go to the bother of re-installing everything, can someone maybe
email me the LKSTIME.dll file so I can shove it in and see if it works?
G
(2,714 Views)
I couldn't find it in my LV directory (7.0). Could it have come from a module I don't have installed? Which modules do you have installed?
The DLL is probably located in one of the CABs on the CD of the owning software. I believe you can tell windows to search through the CABs, so you should look for it there.
However, it might be better (and even faster) to just reinstall, especially if you don't know where it should go. Also, instead of doing a full reinstallation, you can just do a repair (go to Control Panel>>Add and remove prgrams>>NI software).
___________________
Try to take over the world!
(2,706 Views)
No worries, problem solved. Nice people at NI 🙂
(2,677 Views)
