llb manager and subVIs
Hello everyone, i'm working on labview these days (i'm new) and i'm using llb manager to save my VIs, the thing is that everytime i run my main VI, one of the sub VIs would pop up to the screen , do you have any idea what i can do about it ??
Message 1 of 13
(4,233 Views)
Hi, soumayabennasr
First you can check your sub VIs property.
If you dont want to sub VIs pop up, you cancel "show front panel when called or loaded".
Like the following picture.
Certified LabVIEW Developer
Message 2 of 13
(4,224 Views)
I've already tried that, doesn't work Smiley Frustrated
Message 3 of 13
(4,220 Views)
Hi, soumayabennasr
You tried in your main VI or Sub VIs? Must change property in your Sub VI.
Another one solution, you check your sub VI and see your program have this invoke node or not.
This invoke node will open your sub VI front panel.
Patrick
Message 4 of 13
(4,207 Views)
I've tried to change the property of my subvi, and i think the pb is in the program as you've said. I don't have that exact bloc, but I have an open.vi at the beginning of the block diagram like the one in the picture bellow, could i remove it or should i change the open.vi ?
It sounds complicated to me Smiley Frustrated
Message 5 of 13
(4,198 Views)
Showing an image of a high level block diagram does not help at all. You can look at the block diagram of the subVI and determine what's going on or attach the subVI so that someone can look at it.
Message 6 of 13
(4,187 Views)
If you can, please put on your VI and we can figure out what problem in your program.
Patrick
Message 7 of 13
(4,183 Views)
I'm quite new in this , so the subvi is 74000rs232UT
Message 8 of 13
(4,181 Views)
does it help or should i upload the hole project ?
Message 9 of 13
(4,173 Views)
Is it possible that the subVI has been marked as a top level VI in the LLB?
Marking VIs as Top-Level VIs in an LLB
Edit I guess I misread the post.  I thought it opened when you opened the LLB not when you ran it.
Bill
CLD
(Mid-Level minion.)
Message 10 of 13
(4,162 Views)
