llb to directory?
Hi there,
does anybody know if there is a way of converting llb's
(LabView-Libraries) to normal directories (without opening and saving
each VI)?
thanks
(4,039 Views)
> each VI)?
Use the Librarian VIs. They should be available on the ftp site.
Greg McKaskle
(4,039 Views)
LabView 5.1 has this capability
- jeffbinslo
Detlef Haensel wrote in message <374158E4.386E093E@iag.uni-stuttgart.de>...
>Hi there,
>each VI)?
>thanks
(4,039 Views)
In LabVIEW 6 you can use the VI Library Manager to convert your llb to a directory. Select your llb on the left side of the window and then select Convert LLBs to Dir. This will create a directory with the name of the LLB and inside will be all the VIs that are located in LLB.
(4,039 Views)
