load a .pcap file
I m new in a forum and I try to do the same manipulation. In my project I want to work in pcap file (to do that I need open a pcapfile).
So I need to open a pcap with the pcap function "pcap_open_offline(). I keep on and modify the .cpp file with this add :
EXTERNC EXPORT int32 lvwpcap_open_capture_file(const char* file, LStrHandle* error_string)
char tempbuf[PCAP_ERRBUF_SIZE];
pcap_t* p = pcap_open_offline(file, tempbuf);
int32 retval = 0;
if (p == NULL) {
SetString("lvwpcap_open_capture_file: impossible de lire le fichier", error_string);
retval = -1;
return retval;
So I modify this file and after compile in a new dll.
Then I export my dll in labview (right clic connectivity -> export dll). I add entries and return in my dll parameters.
But I have severals problems :
My file in entrie is a float char (uint8 in labview) I try to link this with path file function but I don't arrive to convert in a good type.
I don't find pcap file in my dll output.
Can you help me to resolve these problems ?
Thank you.
Regards Sébastien
Message 11 of 14
(1,598 Views)
Hi Sebleon83.
In this case you can use directly the wpcap.dll. (npcap installed in winpcap compability mode of course).
I put an example this VI here.
Afterwards just do the reading with pcap_next or pcap_next_ex, until you get an error (-2 is EOF).
Hope this helps...
BR
Marcus
Message 12 of 14
(1,549 Views)
The file format is not super complex. I was able to get most of what I need with this code (no DLL calls, pure LabVIEW) to parse the pcapng files.
Message 13 of 14
(1,292 Views)
I was able to get most of the data(starting from Ethernet header to payload) I wanted from reading the pcapng file as a binary file. However, while reading it, I was not able to get any timestamp information. Any idea how I can get it? The content of the wireshark log file will have the byte order info and after that starts with MAC addresses.
Message 14 of 14
(368 Views)
