load associated files in application
Hi
I have created an application that creates input and output files.  I have been able to associate input files to my application so that by doubleclicking on those input files the application will be launched with the inputs loaded.  Now i was wondering whether it was possible to load another input file while my application is already open by doubleclicking on the input file.
The Problem I am having is that i used the Application:Command Line Arguments Property to load input files but this only seems to work when labview is launched and does not change when i double click on another file while the application is running.  Is there a solution to this?
Reza
(2,714 Views)
(2,706 Views)
And then esp. this link
Ton
My LabVIEW Ideas
(2,694 Views)
