load class from XML (Dynamic Dispatch)
It has a horrible side-effect of completely bypassing the Dynamic Dispatch typing.
This can lead to some nasty goings-on....
Here is an example I have made for AQ.
Shane.
Message 11 of 17
(1,842 Views)
I have confirmed this is a bug with 8.2, 8.5, 8.6 and the next LV version. Unfortunately, we're too late in the release cycle to fix it for the next release, so it will be addressed for the release after that. Thanks for letting me know about this. I've got the compiler team working on it already. This worked at one point in LV8.2 before release, but it seems to have been removed before release and has never been fixed since then.
Message 12 of 17
(1,822 Views)
Do we have a CAR# for the Bug thread?
Shane.
Message 13 of 17
(1,820 Views)
No CAR. It's a big enough change that it gets a spec and design document.
Message 14 of 17
(1,813 Views)
I am sorry to dig out this old thread, but I apparently have the same problem.
Is there a solution to this pesky shinanigance? Or do I have to re-implement the same VI over and over again (at least the wire color changes once in a while)?
Thanks in advance!
PS: Is there a way to change a VI to dynamic dispatch (for override) after creating it? I just cannot find the button 😞
LVOOP is a mess for beginners imo.
Message 15 of 17
(1,561 Views)
Hi Questionmarker,
to make a dynamic dispatch VI non dynamic, there is no button. You have to edit the connector pane. You will notice that dynamic input and output have a dotted frame. Right-click on the terminal in the connector pane and go to "This Connection is" and choose something other than dynamic dispatch.
After that the VI will be a standard static one.
joseph
Message 16 of 17
(1,543 Views)
Hi Intaris,
I ran into exactly the same problem trying to solve the same problem. My class even has exactly the same name. Have you found a solution for this?
Message 17 of 17
(1,084 Views)
