load from ascii fails
I want to import 2 Signals from an ascii file. The Ascii File looks like:
A   B        C
1   234    1.324
2   234    1.234
3   563    1.578
4   643    2.324
5   734    3.234
6   832    2.234
7   923    1.234
I use the Express Vi "Load from Ascii".
First Signal:         B y-values, A x-values (time)
Second Signal:    C y-values, A x-values(time)
In the Express VI itself everything works fine.
But if I start the whole programm it says:
"Error -90904 occurred at an unidentified location
This error code is undefined. No one has provided a description for this code, or you might have wired a number that is not an error code to the error code input."
This only happen, if I set A to the y-values. (but this is important)
How can I prevent this error?
(3,082 Views)
I couldn't find the 'Load from Ascii' express-vi on my LV8.2.
To load such a 'simple' ascii file I would do this:
- load the whole file (if it's not too big)
- strip the first 3 lines
- convert the rest using 'spreadsheet string to array'
- get the needed columns by 'index array'
(3,077 Views)
Oh sorry, I forgot to mention, that this VI is from the System Identification Toolbox.
Now I want to create a waveform and i need the samling time for this.
How can I insert the first column (time) to be the X-Value of the waveform?
(3,074 Views)
Hi Myjestic,
the waveform datatype just takes t0, dt and an array with all y-values. So you just have to give start time and time between samples instead of the full X-axis (=your first column).
(3,066 Views)
🙂 okay
than, how can I calculate the average dt between the single values of the first column (time)?
(3,061 Views)
the A column seems to contain only integer values:
1st method) take (last_time-first_time)/number_of_samples (easy way, when dt is roughly the same for all samples)
2nd method) calc the difference between two consecutive time values and get the mean of all these dt-values (there's a Mean function somewhere in the palette)
(3,048 Views)
