load<>save panel<>ascii-file
I would like to have a vi which creates a human
readable ascii-file from any vi's front panel.
If possible with the option to load it back into
the vi. This way a situation can be saved as kind of a version. Also using the same settings in another vi could be handy.
I have made a vi which makes creates a file containing control names, flattened data and typedefs of the controls, but it's binary !
Is there a way to translate these codes to uman readable code ?
This would bring me closer to the solution.
(2,530 Views)
Therefor you can use the ini file vi's. You can create a new section for
each control and assign the informations (name, flatten data) with
different keys like:
[Control_01]
Name=...
FlattenData=...
[Control_02]
In some cases you are not able to see the real value, for instance the
flatten data. Just try it out.
Henrik
> Is
(2,530 Views)
