load real time into cRIO 9012
Hi I want to know how I can load real time into cRIO 9012?, I have LabVIEW 2010, MAX 4.7. I hope you can answer.
Thank you.
(2,634 Views)
Are you trying to program NI-RIO drivers onto the cRIO?  You can do that through MAX, expand Remote Systems to find your device's software element.  There will be a button to install software.
If you're looking at developing a real-time application you'll need to buy the NI Real-Time development and maybe FPGA license.  There's a whole world of information starting at NI's real-time page, I suggest reading the main topics there before starting any work.
https://www.ni.com/en/shop/data-acquisition-and-control/add-ons-for-data-acquisition-and-control/wha...
--Using LV8.2, 8.6, 2009, 2012--
(2,629 Views)
Hi!!
Check out the following link!
https://learn.ni.com/learn/article/getting-started-with-compactrio-hardware-and-labview
It's a quick guide on how to setup a cRIO controller and start developing a LabVIEW application in Real-Time.
Hope it helps!
Regards!
Anuar Rojas
Anuar R.
National Instruments México y Latinoamérica
Ingeniería de Aplicaciones
www.ni.com/soporte
(2,620 Views)
