load text ring
ok i'm slightly lost .
I need to take a tab delimited file in the format
selection name,hex string
the first item should be in a ring control and provide me the hex string as the result.
i know this should be simple but i'm missing something.
any help in the right direction would be appriciated
(2,490 Views)
tomsch1;
Download from my website the VI "Read Strings from Spreadsheet File.vi":
http://www.jyestudio.com/visecurity/vi/readstringsspsheet.zip
Then check the attached example. The .zip file also includes a sample text file. This should give you a start.
Regards;
Enrique
Mensaje editado por Enrique
www.vartortech.com
(2,486 Views)
