loading a very simple .dll using vectors
Dear all,
I'm trying to load a .dll  in labview that I generated from C++ using code::blocks.
This simple .dll is just a test copying a input vector to the output (vector also).
The process crashes during import.
I attached the .cpp and .h file for information
Are vectors handled in Labview ?
Any help would be very much appreciated here
PS : it wouldn't let me attach the .cpp file so I copy past the very simple code here bellow ( the header file is in attachment )
#include "mainRItoIR.h"
void DLL_EXPORT testInputOutput(std::vector<double> &output, std::vector<double> input)
output = input;
thanks so much
Oliver
(3,492 Views)
You can not pass C++ objects to a Call Library Node function. C++ object ABI are compiler specific so LabVIEW has no way to even try to implement them in a compiler independent manner. Therefore NI never even attempted to do that.
You need to pass standard memory pointers to the DLL.
void DLL_EXPORT testInputOutput(double *output, double *input, int numElm)
      memcpy(output, input, numElm * sizeof(double));
And you need to preallocate the output array in LabVIEW of course!
Rolf Kalbermatter  My Blog
(3,435 Views)
Hi Rolfk,
Thanks so much for your great help, this saved my life.
Thanks again !
Best regards
Oliver
(3,396 Views)
