local variables vs property knots->value
What is the advantage of local variables versus property knots (value)?
They tell in the manual, that for every local variable there is always a copy made of the original
input/indicator. If i use the property knots (value) no copy is made.
So what is the use of local variables?
Which methods exits else to avoid too long wires?
Sneff
(3,152 Views)
Hi Sneff,
"to long wires" doesn´t exists. To use wires is better then everything else! A good solution to have a clearly arranged block diagram is to use a state machine architecture.
Mike
Message Edited by MikeS81 on 05-06-2008 01:43 PM
(3,151 Views)
As Mike already told you, you should try to avoid variables (both locals and globals) just as usage of property nodes value. There are several reasons for this:
- Bad diagram design with variables
- Trying to work around a bad architecture by using variables instead of switching to a fitting one
- race conditions (insecure datamanagement)
- performanceissues
Besides that, using variables vs propety nodes (value) are the following:
- property nodes are always executed in the UI thread => slow
- variables as well as the property node copy the data of the control\indicator in case of reading => exposed, well, predestinated for race conditions
hope this helps,
Norbert
Norbert
Expert: Geometry
(3,145 Views)
Thank you,
but what do you mean with state machine architecture and race conditions?
Greetz
Sneff
(3,132 Views)
http://en.wikipedia.org/wiki/Race_condition
http://en.wikipedia.org/wiki/State_machine
If you want to know how a state machine in LabVIEW looks like, you should either try the example finder or the "design patterns" in the template browser (File->New).
hope this helps,
Norbert
EDIT: Updated links for "link-behaviour"
Message Edited by Norbert B on 05-06-2008 07:29 AM
Norbert
Expert: Geometry
(3,123 Views)
study here and here
(3,119 Views)
Yeah, thank you that helped.
I try to code my VI like a state machine.
This fits perfectly to the rest of my concept.
Greetz
Sneff
(3,094 Views)
