localhost IP from labview
Does anyone have any idea how to get the IP address of the machine running
labview from labview?
Chris Delaney
(7,103 Views)
Forgive me. I just found the shell exec VI included with the UNIX version
of LabVIEW. That will greatly simplify things. Sorry for wasting the
space...
On Wed, 21 Jul 1999, christopher sean delaney wrote:
> Hi,
> Thanks,
> Chris Delaney
(7,103 Views)
You can use the 'String to IP' icon to and get your ip address. Either
wire in an empty string, or don't wire anything at all. The address
comes back as 4-byte digit, each byte represents one section of the dot
notation address. For instance if your ip address is 255.0.255.0 the
value that is returned is 3232235703 decimal (FF00FF0 hex). This
operation uses a few milliseconds.
If you don't want to parse it yourself then you can wire the result into
'IP to String'. I don't recommend this because this operation can take
*seconds*.
All functions mentioned are found in the Functions>Communications>TCP
palette.
ej
In article ,
> Hi,
running
> Thanks,
> Chris Delaney
Sent via Deja.com http://www.deja.com/
Share what you know. Learn what you don't.
(7,103 Views)
I need o get a machine ID for data verification, Weh use DHCP so the
IP's change ever time a machine is rebooted. Is there a way to get the
Ethernet hardware addr, or other serial num?
-jp
>ej
In article,
christopher sean delaney ents.uiuc.edu> wrote:
> Hi,
> Chris Delaney
(7,103 Views)
