locate cursor programmatically
Hi All,
I have been trying unsuccessfully to have a program start up with three cursors on three overlays move to the frequency input by the user as they start the program.  It may do the first plot, but that is it.  The old cursor (7.1) was much easier to edit than the new one (2013).  Help.
Ron Brook
(3,504 Views)
Hi Ron,
Thanks for the question. Just to clarify what it is you are trying to do, would it be possible to include a screenshot of what this looked like in LabVIEW 7.1 or even some more information about your application? What type of controls and indicators are you using? At that point it may be easier to understand exactly what it is you are trying to accomplish.
(3,449 Views)
I am trying to use the property nodes for a plot to move the cursor to a location specified by the user when the vi starts.  For example, if the speed of the motor is 1800 rpm, and then user types that in, I am assigning that variable to a property node called 'cursor, position, x position'.  It doesn't seem to do anything.  I also tried 'cursor, index'.  Nothing.  Do any of these work?
(3,421 Views)
Did you remember to Create a Cursor via CursorList and set the ActiveCursor?
(3,417 Views)
Yes.  The cursors are all created, all active and all work.
(3,413 Views)
Accepted by topic author rwbrook@integratedps.com
I meant with your Property Node for the WFGraph.
You need to set 3 properties.
First Set the ActCrsr.
Then Set the PosX and PosY.
Only one Cursor can be active at a time and that is the one that you edit.
(3,410 Views)
Yes!  Thank you.  It's a mess, but it works.  I tried everyway I could think of to make it into a for/next loop, but because of all of the invidual control for the plot colors, couldn't do it.
I will pass on Kudos, thanks again.
Ron
(3,386 Views)
