locating time the signal crosses a threshold
Greetings,
I realized that the peak detection vi only detects the peak locations. Is there a way where i can detect the first location or point which the signal first crosses the threshold instead?
Thanks.
(2,603 Views)
HI
Use Transition Measument VI
You can pass the threshold using reference level input and you will get the time for crossing that point from measurement information output of Transition Measument VI.
Hope this helps
Regards
Santosh
(2,593 Views)
