location of old version 8.5.1 in LabVIEW 2009
I am using LV2009 SP1 version and made a code for distribution as a installer.
In preparing the distribution file, I was request to insert LV8.5.1.
When I inserted that version, the application builder couldn't recognize the CD though CD was okay.
I don't know which component(s) is related to the verion 8.5.1 though NI system component is required on the builder dialog.
I checked Measurement and Automation Explorer as attached in the following.
Can you tell me how to check the component of old version?
labmaster.
(2,455 Views)
I have seen that before. Did you install the proper disk and release it requested (third quarter for example). Whenever I get a release that I plan on using, I copy a disk image to a hard drive so I always have it available.
(2,432 Views)
Yeah, I installed the developer suite version of 2009. The service pack of 2009 was installed separately.
Have you an idea for my trouble?
(2,408 Views)
What I meant was did you insert the correct disk/release of the 8.6 disk it was requesting? There are 4 or 5 disks.It can be picky about which one it needs. When that happened to me, I installed it once and it archived it for future builds.
(2,397 Views)
