lock all vi"s in a lvlib
I want to password protect a .lvlib and have that protection propagate to all vi's in the library.  Unforturnatly when you lock the .lvlib it only prevents you from add/remove vi's from the library.  You can still edit vi's in the library unless you individually edit the properties for each vi.
Message 1 of 8
(4,550 Views)
Then you might want to put that in the LabVIEW Idea Exchange.  That would be an excellent idea that NI should implement.
Message 2 of 8
(4,548 Views)
Using VI Server you can open a reference to each VI in a directory, set a password, then save it.  I believe VIPM has this feature built in when making packages now.
Message 4 of 8
(4,522 Views)
The feature is in VIPM Pro, but not the free version.  I will take a look at writing some scripting to do this using VI Server.  I will also consider purchasing VIPM Pro.
Message 5 of 8
(4,508 Views)
It is a simple VI and when I have a PC tomorrow I'll see what I can post. That being said VIPM pro is nice for project scanning and VIPC file creation.
Message 6 of 8
(4,500 Views)
Attached is a VI that will lock or set a password for all VIs in a folder.  With progress and cancel.
Message 7 of 8
(4,464 Views)
I added an invoke node for saving each file after setting the Lock State. This was needed in order to make the function work as expected in LV2018. I can't speak to whether it is needed for older versions of LV.
https://forums.ni.com/t5/Example-Code/Programmatically-Lock-and-Save-a-VI-Using-LabVIEW/ta-p/3504647...
Message 8 of 8
(3,169 Views)
