I am using two tab controls on my front panel, one of them inside of a tab of the other one. The "inner tab control" has a cluster inside of one of it's tabs. That cluster was "autosized" and the tab control was sized around it. My problem is that every so often, while executing my vi, one of either tabs expand it's boundaries. Sometimes is just the cluster, and sometimes the inner tab control dissapears. I looked for hidden controls within both tabs and the cluster with no findings. I will appreciate if someone can tell me how to lock the size and position of this controls.
