lofar
I'm trying to display a "lofar" diagram using intensity chart. The problem I have is that I don't know how to make the chart to update up-down instead of right-left. I basically want the swap the axis so I will have the frequency at x-axis and the the on y-axis. Is this possible?
(4,263 Views)
Hi ahmalk,
use an intensity graph instead of the chart: now you can do whatever you like to do…
(4,244 Views)
Hi Gerd!
I tried that as well. starting from a fixed size 2D array in which I insert new elements and delete the old one. The problem is that the time don't get updated.
(4,235 Views)
Hi ahmalk,
it's a graph and you can adjust the axis labels with property nodes…
(4,228 Views)
Thanks!
I will try that. Smiley Happy
Spoiler
(4,219 Views)
