logarithm
I need to compute the exponential of a arbitary logarithm in CVI.
In the term x=aö  x and a is known.
Can not find a function the computes n
I do find log functions on bases 2 and 10, but n in my case differ from that.
Anyone ?
Regards Per Borgvad
(4,089 Views)
This is a LabView forum, not CVI.
Anyway, let logn(x) be the logarithm of x, base n:
logn(x) = log(x)/log(n) = log10(x)/log10(n)
Paolo
LV 7.1, 2011, 2017, 2019, 2021
(4,081 Views)
At the wrong place at the right time.
Anyway I do not follow, let me rephase :
(p0/p1) - (p0/p2) = a   known value
x = (dv/v)^n   also a known value
n= Help me out ?
(4,071 Views)
Sorry I'm not catching you. You mean that x is known? What are the variables here? And what's the relation between the two equations - they don't share any term...
Paolo
(4,058 Views)
I will make a guess for 2nd eq: you know x and (dv/v), you want to know n:
n = logbasedv/v (x) = log(x)/log(dv/v) = log10(x)/log10(dv/v)
is this what you need?
Paolo
(4,050 Views)
Thank you for your respons.
To clearify my problem
(p0/p1)-(p0/p2) = (dv/v)^n
p0,p1,p2,dv and v are known.
This is an hydraulic accumulator calculation where the intention is to see the effect
on n by varying the others.
Still n= ???
Regards Per
(4,046 Views)
ok I understand now; the answer is in message 5, replacing x with (p0/p1)-(p0/p2):
n = log(
(p0/p1)-(p0/p2))/log(dv/v)
Paolo
(4,024 Views)
