logarithmic decimator?
I am displaying an array of 1 million points (linearly spaced) on a graph with a logarithmic axis. That's a lot of points, and my program slows down consequently. Also, the points bunch up on the right side of the scale, so i can't see multiple graphs properly.
Solution: I would need a logarithmic decimator, to take a subset array from the original, with logarithmically spaced data points. That way, my data will look evenly spaced on a logarithmic graph.
Anyone have a subvi which will do this? Any suggestions for an algorithm that will do this?
aleks.
(3,552 Views)
do a for loop log10(array size) get 10^i item and index it out.  This should index out 0, 10, 100,1000,10000, 100K and 1M element and run very fast.  I think this should work.
Paul
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(3,544 Views)
I've effectively implemented the same thing in a subvi just a moment ago.
It's  a while loop which runs, and creates an array of indices to remove from the original array. The algorithm is
INDEX_TO_REMOVE = LAST_INDEX_REMOVED - round(1.01^i)
LAST_INDEX_REMOVED starts at ARRAY_SIZE
1.01 is a fraction to be fine tuned
"i" is the while loop index.
The part which takes a long time is remove the entries one by one... i still need help with that.
I guess what you suggested simply keeps entries, whereas i've been removing them. I'll try to reverse my method, to reduce the time it takes.
(3,536 Views)
Here is what i was thinking, will give you the the solution in O(Log(n)) time very fast.
Paul Falkenstein
(3,515 Views)
Oops forgon thew attachment
Paul Falkenstein
(3,513 Views)
