logging real-time data into the text file using time of pc
I have a simple VI which acquires waveform data from a single channel and writes to a text (.lvm) file.
Please see the VI attached.
The format of the text file is as follows (as an example, for sampling rate 1000 Hz):
Time (s), Value
0, 5
0.001, 6
0.002, 4
However, I want the VI to write actual system time while logging data into the text file. Example shown below:
Time (yyyy/mm/dd HH:MM:SS.FFF), Value
2012/09/10 13:31:23.000, 5
2012/09/10 13:31:23.001, 6
2012/09/10 13:31:23.002, 4
I would be grateful if you could help me with this problem.
Thanks!
(3,021 Views)
Typically, you would use the base functions for Data acquisition and Logging to file.  Using the base LabVIEW functions gives you more flexibility. (Way more than using express VIs). I would not use the Write to Measurement file express VI, but use "Write to spreadsheet" VI.
Certified LabVIEW Architect
(2,875 Views)
I will provide more info later.
(2,872 Views)
See here  Time to xl  (converts time from the LabVIEW scale and epoch to the scale and epoch used by Excel.  you do have to manually set the cell formating to time/date in ecxel to view the number as YYYY/MM/DD HH:MM:SS format
Don't forget to kudos the idea here
the excel Format specifier for your example would be "yyyy/mm/dd h:mm:ss.3" without the quotes
Spoiler
(How bout that? three in one day!)  Smiley Very Happy
(2,866 Views)
cool suggestion Jeff
(2,859 Views)
