login
Hi all :
Please look attach file that I send , I build a sub vi which called login with password , but my problem is when I press on login bottom this sub vi must popup to set user name and password
But this not happened
What's I doing wrong?
wisam
(3,641 Views)
wisam,
since you didnt attach the subvi itself, i can only suspect what you are doing. But i am pretty sure to know whats wrong:
Have you configured the VI as "appearance: dialog"? I dare to say: no....
(You can find that in the VI-settings)
hope this helps,
Norbert
Norbert
Expert: Geometry
(3,637 Views)
Hi all :
I have you configured the VI as "appearance: dialog"? (You can find that in the VI-settings)
who can i find  VI-settings
thanks
(3,623 Views)
Your MainScreen_b.vi has to be set to Window-Appearance: Dialog to popup.
You can find the VI Settings when you open the VI and press Ctrl+I.
hope this helps,
Norbert
Norbert
Expert: Geometry
(3,621 Views)
