logrithmic weigthed mean
how i can create a subroutine to calculate logrithmic weigthed mean pressure and diameter i know the the subroutine for simple mean but not for this :
Mathemitical formula is:
logdg=Σ ni( logdi)/N
Also need to calculate Weigthed geometric mean  and standard deviation 😞
Can anyone please help?
(3,667 Views)
The basic idea is to use a FOR loop to step through all of the values (of diameter, for example) and do the inside-the-summation calculation for each.  Sum the array of outputs and divide by the total number, per your formula.
(3,646 Views)
Are you in the same class as sheeham?
http://forums.ni.com/t5/LabVIEW/weighted-mean/m-p/303884
(3,629 Views)
is it possible to send me a image or the in the file form so i can run in labview please ?
(3,619 Views)
It is more appropriate for you to supply what you have tried and ask a question than it is for us to supply an answer to your homework problem.  What have you got so far and what problems are you having with the code?
(3,615 Views)
hi,
I tried to create a Vi for mean and standard deviation but i wnat for weigthed mean and weighted standard deviation please suggest wat next i should do?
(3,572 Views)
You actually didn't create a VI for mean or std. deviation.  You just used the built-in LabVIEW subVI.
That's okay.  You can open up that subVI and see how they calculated it using basic LabVIEW primitives and compare it to the equations.  Then you can figure out how to modify it to work with whatever mathematical equations you have found for a logarithmic weighted version.
(3,564 Views)
