looking for 5.1 version of the VI "copy a file without error if the file exists"
If you use the standard VI copy then the function isn't executed if the file already exist. There's an example on the NI site that perform the copy disregarding if the file exist (without error)but it's only for version 6.0 and 7
(2,773 Views)
The way this is done,
Check If the file exists
If it exists, then delete it first, then perform the standard copy
(2,773 Views)
You can use the delete file function with the target path befor you copy
the file, so you make sure that the file does not exist.
(2,773 Views)
