looking for a better way to add many arrays
Hi there,
  I am new to G lanuage and I find it pretty hard to understand the way to deal with array in labview. I am trying to create the sum of more than 15 (discrete) consine functions each with different frequencies. I am using the loop and consine function to generate the array for each cosine but to add all of them (element-by-element addition), must I use a loop again? I really curious if there is any other way to generate the sum of all those cosine at a time and convert the result into a single array. Someone suggests to use formular and for loop, but I don't understand that, how to use formular and how to make the outcome array?
(2,630 Views)
Accepted by topic author dragondriver
You can create and add in the same iteration using a shift register.
Here's a quick demo adding five sine functions with different numbers of cycles. You should be able to adapt it to your problem.
(2,628 Views)
Thanks a lot 🙂
(2,617 Views)
