looking for a vi to visualize multiple tdms, measurement explorer
is there a package that acts like a scaled down version of Diadem?
I need to scan some folders for tdms files, filter them by properties, select channels and display them.
Would be done quickly, but since its quite a generic thing, I wonder if you know a project that already has this functions?
But my searches gave me no results, which suprised me.
Diadem would be overkill and getting my boss to pay for it is another deal.
Thank you, Bow
(1,759 Views)
Hi Bow,
For the "generic things" you can use the TDMSViewer function, that comes with LabVIEW…
  • To scan a folder for TDMS files you  may use the ListFolder function.
  • To "filter for properties" isn't generic at all, each file/measurement might have different properties. So you need to implement your filtering on your own.
  • Selecting channels and display their data is generic: learn from TDMSViewer…
(1,756 Views)
Thanks Gerd,
I wasn't looking for an advice on how to make it. I'd have no problems with that. I am looking for code to reuse.
I know about TDMSViewer, it can only open one file at a time. But if this discussion gives no results, I will probably
take parts from it.
(1,747 Views)
The SCOUT TDMS File Viewer
May be exactly what you are looking for.   Check the link and try it out.
(1,733 Views)
That is almost perfect. Has much more functions than I need, but that's no problem 😄
would love to have it as a vi though to implement and adjust it
(1,722 Views)
