looking for integer to binary bit element :::
hi
i am looking for an an element that convert singed intger 8bit to indiviual bit
i use lab view 2011
i try but the element that convert the array miss from my programing minu
regards
m.s
hi ?Q>
Message 1 of 10
(4,722 Views)
Accepted by topic author mangood
Index Array, simply pull down until you have 8 elements.
Message 2 of 10
(4,717 Views)
""Index Array, simply pull down until you have 8 elements.""
is this mean thier is no element ??
during search i see the pic  from old topic in ni.com
 what is this element~!
hi ?Q>
Message 3 of 10
(4,711 Views)
You want "number to boolean array."
[Edit] Didn't realize you had already converted the number to an array.  If this is so, then Darin's got the goods.  🙂
Bill
CLD
(Mid-Level minion.)
Message 4 of 10
(4,701 Views)
In case you want booleans or numbers.
I hear good things about the NI online tutorials, they may be very useful for you.
Message 5 of 10
(4,697 Views)
both i want.. but what is the name of this converter that use it in last replay i think lab 2011 does not contain this element
hi ?Q>
Message 6 of 10
(4,682 Views)
here what i want exactly the converter from array to individual bits
hi ?Q>
Message 7 of 10
(4,680 Views)
Depending on your browser you can drag that code snippet directly to your block diagram and the code will appear.  Context Help will show you that it is Index Array and certainly exists in LV11.
The stretching is a convenience to allow you to index multiple consecutive elements.
Message 8 of 10
(4,665 Views)
Simply click on the bottom edge and drag down to resize the index array function.
Darin- the resize feature of these functions is actually conspicuously missing in the core curriculumSmiley Wink
Message 9 of 10
(4,653 Views)
thank alot
here i can see the bestHeart poeple in world
regards
m.s
hi ?Q>
Message 10 of 10
(4,647 Views)
