looking for state machine template for menu driven application with idle loop
We need a state machine template for complex menu driven application with idle state that waits for commands. We have LabView 6.0
(3,719 Views)
Have you looked at the shipping example called User Interface Event Example.vi? It is a queue driven state machine that handles both pull down menus and front panel controls. If you have looked at it, what other functionality do you need?
(3,718 Views)
That should be fine if we could get it in LaBView Revision 6
(3,718 Views)
It ships with LV6. Help>Examples>Advanced>User Interface Developement>User Interface Events.
(3,718 Views)
RayPh,
Below are some good examples on how to use state machines in LabVIEW:
Using a Menu-Driven State Machine in LabVIEW
Template for Large LabVIEW Application Development
Also, there is new toolkit available for LabVIEW 7 Express called the State Diagram Toolkit that greatly simplifies the creation and management of large applications. You can find more information on the toolkit at http://sine.ni.com/apps/we/nioc.vp?cid=12314〈=US . This is a great toolkit if upg
rading is an option.
Matt Friedman
(3,717 Views)
