loop array one by one
@H7N wrote:
Whatever you have attached seems incorrect based on the earlier problem description:
  1. Your loop completes in nanoseconds, so the stop button is useless.
  2. Since the maximum number of iterations is known, a FOR loop is more useful.
  3. Your code DOES NOT update the output interactively. It is a one-shot deal.
  4. What is the size of the input array? If you want to process all elements, simply get rid of all code and place a +1 on the array wire.
  5. If the input array is larger, use "reshape array" to truncate, then add one.
  6. there is a "+1" primitive.
Did you really attach the code you intended to show us?
Message 11 of 11
(939 Views)
