loop break hot-key
Dear Forum,
My collegues and I are new users of Labview and we were wondering if
there is a way to break an (accidently programmed) endless while loop.
The problem, in its simplest form, is a while loop with a dialog box
inside and the output of the dialog box tied to the while loop's loop
contidion box. I've played around with it a little, but the only way I
can find to break the loop is Ctrl-Alt-Del, which forces the closure of
Labview altogether.
Kind regards
Michelle Harmos
Sent via Deja.com http://www.deja.com/
Share what you know. Learn what you don't.
(5,119 Views)
Does the dialog box have two buttons? The cancel button yeilds a False
output, and if that's the only thing connected to your loop condition, it
should halt. If there are other conditions hooked up to your loop
condition, put a case statement after the dialog box output to control
them.
Rick
rick@csciences.com
Chesapeake Sciences Corp.
1127B Benfield Blvd Millersville, MD 21108
Tel: (410) 923-1300 x3430 Fax: (410) 923-2669
(5,119 Views)
If this happens in development hit Control-. (Control and the period
key). This will stop the program. You can also use this to stop a program
that has been coded to Exit LabVIEW when a Stop button is pressed and there
are no menus.
--Doug
mkh113@rsphysse.anu.edu.au wrote in message <7qng8v$l0j$1@nnrp1.deja.com>...
>Dear Forum,
>Labview altogether.
>Kind regards
>Michelle Harmos
(5,119 Views)
Try this: press + . (LabView shortcut to
stop a program) and maintain pressed. Answer the
dialog box with the mouse, the vi will perhaps
stop.
In some cases, you may answer many times the
dialog box before the vi stops.
I think that the VI must accept to be stopped by
the user (Vi Configuration menu: show stop button
or something)
Laurent.
In article <7qng8v$l0j$1@nnrp1.deja.com>,
mkh113@rsphysse.anu.edu.au wrote:
> Dear Forum,
li
> Labview altogether.
> Kind regards
> Michelle Harmos
(5,112 Views)
